Ran a ground due to ice.
1_bar_goes_far
40
Feb 4, 2003
Appleton, Wisconsin
I was going home for lunch and the roads were iced over. I was doing 20 or so and went to slow down and the abs locked the peddle and I went throught the turn and over a curb and into someone's yard:cry:. The rim on the front left is dead and the left rear was bent too. Now the car pulls to the left, the camber is way off on the front and the car tilts to the left a lot. What all do I have to replace to get everything like it should be?
Funny, On monday I slipped off the road to avoid another sliding car and ended up hitting a telephone pole. No serious damage, but now I can get the front end converted to the 97-99. If none of your suspension parts were bent, then you coulld just take it to get aligned, but that's just if your lucky.
well, you definately have to fix the rims. Your suspension is probably all out of wack after that so you should definatlely have an alignment done. That will cover it if there's nothing bent, ie strut mount/ suspension arms. If those are bent they'll have to be replaced or straightened too, the alignment shop will tell you if there is any problem with them.
