Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > 4G63 DSM Tech > Handling Tech
Handling Tech Suspension, steering, brakes, tires, lightweight wheels, bushings, etc.
Reply
LinkBack Thread Tools
Old 12-17-2002, 10:23 PM   #1 (permalink)
Proven Member
Classifieds Rating: (0)
Reputation: bugdoubt is an unknown
ABS question
Ok I guess I've been a little embarrassed to ask this but here goes. When I first bought my car the rotors were warped to heck and when abs was applied it was a nightmare. Well I figured no ABS fuse=no ABS. Well I never really thought about it again till now. Ive warped my second pair of rotors since last spring. Now I know I need to bleed my brakes but here is my question. With the abs fuse pulled is there a problem with pressures in my brake lines(assuming no air in them). Could this be a cause for warping?
I ask because I'm purchasing the Baer track kit and I don't want to ruin them by not using my ABS(i.e keeping the fuse out).
So by not having the ABS fuse in am i going to warp more rotors?
thanks
Offline
Related Auctions
Sponsored Links
Old 12-18-2002, 10:51 PM   #2 (permalink)
DSM Wiseman
Classifieds Rating: (1)
No fuse isn't warping your rotors.
____________________________
Nick Drake
Offline
Old 12-18-2002, 11:00 PM   #3 (permalink)
Proven Member
thanks
Offline
Old 12-21-2002, 07:10 PM   #4 (permalink)
Proven Member
Reputation: DSM_Drew is an unknown
Warped rotors are usually the result of a few common things.
- cheap rotors...crappy chinese rotors made of crappy steel warp real easy. Buy something good like Brembos
- uneven lug nut torque...puts uneven pressure on rotors. Use a torque wrench to tighten them correctly.
- hard stopping...if you're one of those guys who waits until the last second to stop and then stands on the brakes. Take it easier on the stops.
- cold water on hot brakes...the sudden temperature change causes warpage. Let the brakes cool before washing the car, etc
Offline
Old 12-21-2002, 10:54 PM   #5 (permalink)
Proven Member
thanks all good tips did not know about the water thing.
appreciate it
Offline
Old 12-25-2002, 08:14 PM   #6 (permalink)
DSM Wiseman
Quote:
ie follow the start pattern.
http://www.stoptech.com/whitepapers/...otors_myth.htm
http://www.stoptech.com/whitepapers/...abs_122701.htm
Nick Drake
Offline
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Page generated in 0.12967110 seconds (74.18% PHP - 25.82% MySQL) with 9 queries
