What else can I do?
1TuffRS
435
Jun 16, 2002
Well First of all I have a 1997 RS and this is my suspension mod list
Nuespeed Sport Springs
Tokico Illuminas
Added Stock rear swaybar
Front Upper strut bar
Baer Track Brakes w/ optional slotted and cross drilled rotors
Rear Disc conversion w/ slotted and cross drilled rotors
Rear Upper strut bar
17" GSX Rims (which I plan to keep for a while, id rather spend the money going faster in a straight line)
Goodyear Eagle RSA's :(
Im also waiting on some front and rear lower strut bars hopefully they will be here soon.
What else can I do to increase my handling prowess? I know I need some better tires, but I didnt want to ask for suggestions since there is a post about it, but what else is there?
You could add a camber kit and a roll cage. At autoX events you could play with different settings and see what happens. You could also change all the bushings and motormounts in the car to polyurethane. You could add stainless steel brake lines. Tires would probably help the most. That is your call there, I have been using Bridgestone Potenzas.
Well good luck.
well my camber is pretty good now actually. That pic was taken with my old progress race springs and now the car is a little higher. I forgot to mention it before but my car already has stainless steel brake lines, they came with the Baer Brakes, which I got for 200 bucks :thumb: Im thinking about getting a set of the RM Sway bars. One of the guys in my club that autocrosses suggested them. They say that I will be killed when I autocross because the guys I will be going up against will be in the upper ranks of the autocross because of my mods, hehe. Anybody else got any ideas?
