FLex or SS?
TurboDSMer
174
Dec 2, 2003
Burlington, Massachusetts
I will mostly be doing street driving/drag racing and wnated to know which one of the two would be better. I know all of the other options but if i went with Koni's I'd be spending alot, don't really like tokico, JIC's same issue as the Koni's. Know i can get the SS for around 850 shipped, and the Flex for about 1250 shipped. I know i save 400 dollars but is the flex any better than the SS other than the fact that is comes with Pillow mounts and has the teflon coating?
Also i have noticed a couple of camber correction kits and the one that caught my eye the most is the one offered by progressive. Here is the link http://www.wiredspeed.com/store/pro...c=Progress+Alignment+Kit&Cc=CAMBE&qry=Eclipse
. LEt me know what you guys think about it and if it is good. I know i can jsut get the nut and bolt solution for cheaper but this is more attractive to me. Also is there sway bar any good? Thanks Sean.
I have the SS with pillowball mounts.... well at least the front half is still on the car. I wasn't too thrilled with the ride and handling characteristics, and I found a rear set of GC coilovers. The ride is 10X better and the car is much more stable.
I recomend the GC kit. I plan on completing the change by the end of the summer.
The rear camber correction should be done with washers and longer bolts, and I have the Ingals front kit.
