GC coilovers or prokits?? for 1g
Pennywise
114
Oct 14, 2002
Arlington, Texas
I had a civc with skunk 2s and blues. had them about half way down and I hated them with a passion. I'm getting a talon awd within this week. the suspension is horrible thats the first thing I'm going to fix. So what should i go with? this will be street driven, and track. I don't want to be bounceing everywhere! this will go with tok lum or blues. does tein offer a ha kit for 1g's? I just want a comfortalble but performance effective suspension. So prokits or GCs
Tein unfortunately doesnt offer crap for us. I have the Prokits w/ AGX's and I love it to death. Its stiff, but not bouncy. The shock are 8way adjustable in back and 4 up front. It lowers the 1g perfectly, IMO, about 1.75" F&R.... Its cheap and effective
I have the ground control/ AGX setup and would NOT reccomend the front AGX shocks. RRE does a setup using the Koni fronts, it gives you an inch more travel (shortened shock body) and actually has some quality dampening (unlike the front AGX). Be carefull with the spring rates as well, most people recomend much to stiff a rate for street use. I ended up (after much testing) with a 10" 325lb spring in the front and a 200lb 8" spring in the rear. No body roll, not on the bumpstops and therefore a good ride as well...good luck!
