STARION
- 193
- May 30, 2002
Nova,
I'm making these tubular lower control arms (1G) but I need to find a bolt-in ball joint as opposed to the stock pressed-in one. The bolt pattern/ shape makes absolutley no difference, the only requirement is that it is the same diameter as the stock one. Please, don't post unless you're POSITIVE that you know one is the same diameter, because I listened to somebody who said X and X type would be the same, and I went out and baught them, and they're not even close.
-Thanks
-Thanks
