Curing a noisy front suspension?
Ludachris
Founder & Zookeeper
8,836
4,654
Nov 12, 2001
Newcastle, California
Just wanted to throw this out there in case others have had the same problem - I've installed some KYB adjustables, Eibach springs, brakes, and new front axles. I have yet to cure the rattle that occurs when I go over small pot holes. It sounds like a wheel or shock is loose. Everything is tightened down, and the sounds were there before I even started any upgrading.
My thoughts are that the bushings are worn, or maybe the bearings are in need of a change. Any other ideas?
-Check the anti-sway bar bushings, also upper OEM spring perch will rattle if it is not line up with the recess on the strut's recess.
Might be the bumpstops hitting the shock over bumps. Mine does the same thing, but I'm just too lazy to trim a little more off the bumpstop :)
i have that same problem chris, but mine is in the rear of the car. the only time i hear it is when i hit a pot hole or uneven patch of road, however; i belive my problem to be blown out struts; not sure though.
Just wanted to update you guys - I just finished replacing the upper shock mounts on the front, the part that sits on top of the spring and bolts up to the shock tower. It cured about 90% of the rattling noises. HUGE difference! I'm sure my torn motor mount and old tie rods/bushings can stand to be replaced for even more improvement.
