99 RS question.
XX_hollywood_XX
Feb 3, 2004
shepherdsville, Kentucky
Ok, I have had this car about two weeks and the suspension is bottoming out from where their is not enough travel. I have a set of 18's on it and it has about 1" of clearance from the tire to the fender. In curves it rubs the tire if I hit a bump. The coilovers are adjusted all the way up. Question is how can I tell if the coilovers are shot, the shock's are shot, or I need to do something else. It scares me with the tire rubbing the fender around curves. I really don't want to go down to 16 or 17 inch rims, but the car is riding so ruff I could be in one of those chocolate milk comercials. Also, what would adding an airbag kit rid like? Thanks.
If you want adjustable rides....get air cylinders :p Coilovers are ment to sit super low (IMO). 18x9 rims for me on a stock suspension were wonderful....just I bottomed on my rear driver side, the spring back there sux.
How are the air cylinders as far as performance goes, compared to shocks? I know I am going to have to change either the tires, or the shocks, but rim's are not cheap, and then I have to go through the hassel of selling my Motigie MR7 rims and the tires. So I would rather adjust the suspension to something that isn't dropped as low, and will still give me fairly high performance. Thanks.
