TalonTsi_291
- 151
- 1
- Jan 25, 2009
Bountiful,
Utah
Just swapped the car over to E85. Spent some time working on the idle. Everything seems to be moving in the right direction. I've tried doing a few pulls now. I've found that if I'm cruising and go straight to wot the car with pretty much just bog. I noticed everything is really jumpy. Rpm, Est afr, Maf, Inj% ect.. But if I ease into it I can make a full pull. I attached some logs that show it. Cutting out 1 shows it studdering, then a pull with no studder. Cutting out shows it studdering twice. I see that my a/f on the aem is flat lining rich, but I dont quite understand why. Im calling for 14.x and 13.x in the da tables, yet getting 10.0. Dmertz from the link forum mentioned compressor surge. The turbo does have a 4" anti-surge compressor housing. Any ideas?
