2g build
bmil13
Dec 1, 2011
Johnstown, Pennsylvania
Well. I bought his car when I was 17. It is a 95 talon AWD. I traded my dirt bike and like 1000 dollars or so for it. The car had an air filter and 2.5 inch exhaust on it. And I never drove it haha. Never even insured it. After letting it sit for about a year and a half I decided to build it. And that's where I'm at now. I am now 19 and the car hasn't run in about a year since I took it apart.
My goal: .? Haha idk for the car to be faster than it was off the showroom floor.
Parts
6 bolt block
Eagle rods
Ross pistons
Acl race bearings
Balance shaft delete
Arp L19 head studs
Cometic head studs
2g head
Bc valve springs and retainers
Bc 272 cams
Ferrera valves
Ferrera valve guides
Ferrera valve seals
Stock cam gear
Jm fab race manifold
T3 tubular manifold ( don't remember the name)
35r turbo
FIC 1650 injectors
Magnus fuel rail
Direct port nitrous (probably just a 100 shot. I'm undecided)
Drive train
Auto tranny
Sinister 8" converter
Shift kit
Welded center diff
Drive shaft shop 3.5" drive shaft
I think it's called blue wire mod? Idk can't remember the name
Huge tranny cooler
-10 fuel line
Aem fuel pressure regulator
Aem ignition module
Mega squirt
Jays racing alternator relocation kit
Jm fab coil relocation
16" rota slipstreams
Evo 8 steering wheel
Mishimoto x line radiator
Can't remember which thermostat I bought for it. But it's not stock temp
All new control arms in the front and new wheel bearings
Stainless steel brake lines front and back
Unorthodox under drive pulley
Gates Kevlar timing belt
Currently I have 2 deatschwerks 300 lph fuel pumps for it but I am thinking of getting a fuel cell and a magnafuel 4303 pump
I can't remember what else I have. I'll post them as I remember.
Oh yeah the car was originally white. The idiot before me painted it blue. And I am painting it white with blue pearl. I painted the engine bay so far everything else is still blue
I am open to suggestions on suspension. I'd really appreciate it
Also is a stock lsd rear end good? I currently do not have an lsd rear end and was thinking about buying a stock lsd diff.
