fasteclipse1992
- 786
- Jan 17, 2003
joplin,
Missouri
ill be doin an engine swap soon from 1.8 to 2.0 turbo and my question is... i just bought a stock 91 6 bolt flywheel 2.0 non turbo and the engine is a 92 2.0 turbo that originally had a automatic tranny. now the flywheel i got i bought from a salvage yard so i assume it is a 91 talon 2.0 non turbo flywheel as the guy stated it is. the crankshaft on the engine sticks out about 3/8 of an inch and the center hole in the flywheel is too small to fit it. is there shims that go between the flywheel and crank like there was on the automatics flexplate or can the center hole be drilled out larger to fit it?
