Clicking CV joint ?
Jaysgsx14
Nov 12, 2003
Glastonbury, Connecticut
My right front wheel I can feel this weird ticking when im barely on the gas and when i take right turns. When i hit the brake or hit the gad hard it goes away. I did my brakes recently do you think it could be my caliper? what do you think
Check you lugnuts first to make sur ethey are tight. Did it just start when you rebuilt your brakes? If so most likely it is something in the brakes or loss lugs. Next, it actually sounds like the CV joint might be going.
Hope this helps
Jay
Check the lugs first I just had someone replace tires on the van and they didn't have them tight and it had the same symptoms as you discribed.
