slipping...every now and then...
Turbotickler
34
Nov 10, 2003
ok.. I looked at several threads and I think I have an idea, but here goes:
I replaced the clutch, TOB, and all the usual. Problem is, I bleed the clutch and it seems ok for a few days, but then after using the clutch (driving) it goes back to to the floor and barely comes back up. When starting it it acts like the clutch is slipping and moves if it is in gear (clutch engaged)
It seems like I have to bleed the clutch every so many days..
Im thinking I need to replace the master and slave, but am not sure.
can anyone offer any advice??
pull back the rubber boots on the master and slave. If theres nasty brown/black fluid gunky stuff under there its bad mine were both leaking so i replaced them. Everything is all well now!
