How much does a 2nd gear cost?
Originally posted by Wobble
not a "tre spec" one, one from dealership..
My apologies, I am a firm believer of rebuilding items stronger than they originally were. OMG
From Mitsu the gear will cost you ~$50 and then another $30 for the bearings on that shaft, but who knows what else got chewed up in there. Might as well replace the tranny seals too for another $25 and install a trans filter for another $15. What if your 2nd syncro is shot or the hub/sleeve is worn? A new hub/sleeve, if needed, will cost you another $120 (that includes 1st/2nd syncros). What if you need to replace 3rd and/or 4th syncros?
Make sure you go through the tranny and get everything straightened out. You don't want to make dropping your trans a common occurance. Instead iron it all out now and enjoy driving your car.
Well, the local dealership charged me $120 for the gear, $35 for the bearing they damaged pressing it off, and $65 for the pressing of the old gear off and the new one on...
Im not buying a bunch of crap i dont need, I cleaned out the entire case and cleaned all the gears, everything else is in prestine condition (remember this tranny only has like 30k on it) so im just gonna replace what was broke, put in the phantom grip lsd and seal it back up with grey RTV and be on my way..
well, im also replacing the rear main seal on the motor, might aswell,, 12 bux.
He he, I took a few chunks out of my second gear too. The bill wasn't pretty afer that.
