ivanr4g63
- 1,021
- 12
- Jan 11, 2003
Linden/Front Royal,
Virginia
No matter how hard I try it wont shift to reverse not even with the car turned off, any other gear slides in easily, My clutch pedal was low to the floor in order to shift cause it needed a Clutch Master Cylinder but even like this it used to shift reverse no grinding at all, so i figure thats what my problem was, so I replaced the Clutch Master cylinder, tighten the linkage, replace tranny fluid, check for leaks and still It wont shift into reverse, it's kinda weird, not even with the car turned off what to do now...?
the thing is that how come all of a sudden only the reverse shift went bad without giving any previous problems...?
