Cirus_93TSI
- 658
- Jun 30, 2003
Glen Burnie,
Maryland
ok, somethimes, usually only when im parallel parking, the car will stall out when i stop in gear and the clutch is pushed in, it doesnt do it all the time, only sometimes, usually in reverse, but when i was parallel parking the other day it did it in first too, i went to reverse and started backing into the spot, i come to a stop to go to first and finish up and it stalls in reverse with the clutch to the floor, i start it again, go forward and it does the same thing in first, then does it again in reverse
now it doesnt do it all the time, i back into a parking spot every nite when i come home and its only done it twice except for when im parallel parking, it does maybe 2 of every 3 times i parellel park, it seems to only do it if i go into reverse at a real low rpm and then stop while in gear with the clutch in
the clutch seems ok, it still grabs pretty hard and the tranny usually doesnt grind(although the tranny isnt in the best shape), im just trying to figure out what the problem is so i know what i have to replace, its probally the clutch but i dont want to buy a new 2600lb only to find its the tranny
so if anyone has seen this happen bffore or has any info or ideas as to what the problem might be i appriciate ur help and imput
