identifying between a 90 and 91up tranny
stevetford
89
Feb 23, 2002
Wickliffe, Kentucky
Other than counting output splines, is there any other way to identify between a 90 awd manual trans and a 91 newer trans? I was thinkning maybe a number cast on the outside or maybe a certain casting difference. I also hear that there are some x-fer cases in aluminum and iron? Any truth to this and besides being heavier, is the iron unit better? Thanks for any help you guys can give.
Steve
Sure, the number cast on the outside is important. There is an issue with the upper shield being a different size between the AWD 90 and the FWD 92 4G63's. The size difference is at the starter housing. Other than that, I really wouldn't know what else to look for other than the cast number and the splines. I have a 90 AWD tranny and if there is anything you need to compare, just let me know, it's out of the car and just laying there.
I have heard one thing that is strange and I am curious about it myself. Some transmissions are reffered to as having Renualt's, what is that and would this apply to his question on differences?
I just did a swap, took a 91 motor and tranny into a 90. Only difference I have found between the two are the shifter linkages are a little different. I just had to adjust the cables a little bit.
  • For sale Mishimoto Intercooler
    Universal Mishimoto Intercooler $100.00 Brand new
    • jmt2028
  • For sale 2g Mahle Power Pak Pistons
    2g Mahle Power Pak Pistons, factory bore $350.00 Brand new with wrist pins and extra set of...
    • jmt2028
  • For sale 2g Water Neck/Thermostat Housing
    2g OEM waterneck and thermostat housing $60.00 In good condition, came off 1995 Eagle Talon Tsi
    • jmt2028
  • For sale EVO 9 Blow Off Valve
    EVO 9 blow off valve $60.00 In good condition, came off 1995 Eagle Talon Tsi. Comes with factory...
    • jmt2028
  • For sale 2g OEM Camshaft Gears
    2g OEM Camshaft Gears $80.00 In good condition, came off 1995 Eagle Talon Tsi Comes with OEM...
    • jmt2028
