damn driveshaft stuck??
95talontsi
274
Jun 29, 2002
Princeton,
I finally got the front suspension out of the way and I am trying to pull the driveshaft, it's not going I'm prying to the point of the screw drive bending, the car is lifted up but not high enough to fit a pry bar under because of the angle I am at. Any advice??
I did this the other weekend and had that problem (Assuming you mean the half shafts) for the secong time in my life.
I stuck the flat bar (or Screwdriver) in and instead of prying in one constant motion and bending it more, I wiggled the screwdriver like mad back and forth (cus I was mad :mad: ) and it popped out from the jumping around.
Some pics here of my axle install: http://www.plymouthlaser.com/axles.htm
Careful not to damage the seal, but if you do you can replace the same as the xfer case seal fix.
Charles
