turbo flywheel in an n/t? (is it possible)
AdrenilineCrash
783
Nov 9, 2002
Travis AFB, California
heres the deal, im buying a car that is a n/t but its got a turbo tranny. the flywheel is not being engaged by the starter because i think it is smaller than a turbo flywheel. will a turbo fit in a n/t car? i need it to because right now i have to push start my car everytime i want to go anywhere. thanks!
-mike:dsm: -less(but not for long)
Mike,
The turbo flywheel will work. LOL, trust me I have done a ton of research on this. What I would do if I were you would be to take your turbo engine with the aluminum spacer plate, flywheel and clutch and install it to the turbo tranny in the car. Even though the engine in the NT is a 6 bolt 4G63, your turbo engine has the better pistons for the boost and has the oil squirters already machined in. Then you just need to install your turbo ecu, and add the wire for the knock sensor. Do a search or talk to Mavisky, he has done this. You will then need a boost gauge, personally I wouldnt waste my time on retrofiting a stock gauge, just get an aftermarket gauge in a gauge pod or somewhere on the dash. Since the car has a single din radio and a plate over the other din hole you could install it there.
Good Luck, let me know how it goes..
