turboslug
- 38
- May 28, 2003
If the evo uses a 4g63 engine is it possible to swap the tranny from an evo to a dsm, mainly the new 6 speeds they use now?
Read this:
MITSUBISHI LANCER EVOLUTION WRC2 TECHNICAL SPECIFICATION
DIMENSIONS
OVERALL LENGTH 4360mm
OVERALL WIDTH 1770mm
WHEEL BASE 2600mm
FRONT TRACK 1550mm
REAR TRACK 1550mm
ENGINE
MODEL 4G63
TYPE 4 Cylinders, 16-Valve DOHC- Intercooled Single Scroll Turbocharger with
Post Combustion Control System
FUEL SYSTEM ECI Multi-injection
BORE x STROKE 85.5mm x 86.9mm
DISPLACEMENT 1996cc
MAXIMUM OUTPUT 220Kw(300ps)/5500rpm
MAXIMUM TORQUE 540Nm(55kg-m)/3500rpm
CLUTCH Carbon Triple Plates
TRANSMISSION 6 Speed INVECS type Shift
4WD SYSTEM Active Control Locking System
FRONT DIFF Active Control Locking System
REAR DIFF Active Control Locking System
Read this:
DIMENSIONS
WHEEL BASE 2600mm
FRONT TRACK 1550mm
REAR TRACK 1550mm
ENGINE
MODEL 4G63
DISPLACEMENT 1996cc
