transmission bolt sizes
TurboAWD92GSX
198
Feb 18, 2003
any one know the sizes of the bolts that bolt the tranny to the block on a 1g awd eclipse. want to buy new hardware but dont know the sizes and i dont have my old bolts.
thanks
manny
The top 2 are about 1 3/4 inches, 1.5 inches....the bottom front is 2 inches, and the bottom back is 8x1.25(the one that goes the opposite direction) Make sure to use loc-tite RED on every bolt. From what I have seen of your turbo setup and so forth I think your car is going to vibrate alot and trannys tend to back out and shit, causes alot of problems. You can even crack the block where the tranny bolts to it. Bad news. Every time you pull the trans use new bolts that are not stretched and then loctite them saves alot of head aches.
