LSD question
GreddySpyder
414
Oct 21, 2002
Alabama
I'm planning on getting either the phantom grip or bmtranny lsd. I am already going to be paying close to $350 to install my new ACT2100 and resurface the flywheel. Since the transmission will already be off for clutch installation, how much more should I expect to pay over the $350 I'm already paying to get the phantom grip style lsd installed? I wanna make sure I don't get ripped on this. Thanks in advance.
Come on, I know somebody on here has a phantom grip style lsd. How much did it cost to get it installed, and was it installed at the same time as any other parts that require tranny removal?
I took LSD a couple of times. The first time it took over 2 hours to kick in, then it was eak trip to begin with. But it is creepy as everytime I take LSD, I see the exact same pattern, If I am in a large enough area, it will go on forever, amaizng and never losing detail or defination.
I suggest starting out with 1-3 hits, go with Gel tabs as they are PURE and do not include the poisen Stricknine to hold it to the paper (RAT POISEN)
If you are really careful, you can allways take Mescalin, as it is phamasuticle grade and is actually made by our US Governement.
It is ok, pure acid can't kill you no matter HOW MUCH you take, you just may never come back, I know people who have taken enough to trip for a year.
Enjoy and be careful with LSD, some powerful stuff
Congratulations numbnuts!! You've succeeded in being a total waste of space and oxygen on this planet we call Earth!
It should not cost more than $150.00. TRE and most tranny shops charge about $100.00. Its actually very easy to install yourself, but if you'd rather have someone else do it the cost will be about $150.00. Hope that helps.
ACTUALLY< I am getting a Phantom Grip LSD, for your car it is a MUST as it is a FF, and you will need it to accelerate stratite and gets rid of torque steer. My AWD Did not come with a LSD, so My tranny is off and he will put one in for me, charging me $225 installed, he is alos putting in a SIX Puck disk with a 2500 pound PP, a Fidanza Aluminum Flywheel, ALL NEW Srynchros, 3/4 Hub and sleeve, new 1/2-3/4 shift forks, new seals all around, new bearings, GVR4 1st gear and input shaft, symbrosky Stiff shift kit, Stainless steel clutch cable, and BG Synchroshift.
This will be done on Friday, I will let you know. My Mechanic has a AWD DSM with 600 HP on a T-66 and HE never broke his Phantom, good shit.
