Help!!!
LethalEagle
162
May 22, 2002
North Augusta, South Carolina
Satin just installed a new ACT2600 and new Fidanza flywheel friction plate...
Clutch adjustment is still all the way out. WTF is going on? Could I have the wrong Fidanza flywheel? Even the pedals and master/slave cylinders have been changed. Anyone with a guess, please help.........:mad: :mad:
were the new pedals 'good'? did you shim the pivot ball? i hate to be a broken record but i see this post daily.
Pneumo: The mechanic did not check the step... the step should have been correct from the factory.
Zac83: The pedals assembly is new also... and one shim under the pivot ball.
Can someone Please tell me what the clutch slave cylinder rod length is?
I'm not joking.... This is a real question......
Thanks...
