Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > General > Newbie Forum > Problem Diagnosis
Problem Diagnosis Can't figure out the problem? Does the question not fit in one of the other tech forums? New Members can post here.
Reply
LinkBack Thread Tools
Old 10-11-2008, 09:39 PM   #1 (permalink)
Proven Member
Deadly BlaZe's Avatar
Region: Southeast
Classifieds Rating: (0)
Reputation: Deadly BlaZe is more helpful than not
Car shifting weird..maybe shifter linkage?
I was driving in 5th gear and noticed when I popped it out of gear, the shifter wasn't sitting in it's usual position (a bit higher up). I tried then going into 4th and it would not go in. I tried going into 3rd and it was fine, then I tried 4th and it went in. I tried doing the process again, going into 5th and then taking it back out, and it was in the strange position again, and still would not go down into 4th unless I went into 3rd first. My guess is that it's the linkage. Does anybody know the process of adjusting the linkage under the hood?
____________________________
Arthur
'92 Eagle Talon TSi AWD (6/4 w/LSD)
Offline
[posts] Reply With Quote
Related Auctions
Sponsored Links
Old 10-11-2008, 09:42 PM   #2 (permalink)
Proven Member
Region: Southeast
Arthur
Offline
Old 10-12-2008, 09:41 PM   #3 (permalink)
New Member/Lurker
Region: SoCal
Reputation: e39a is an unknown
Theres No Adjustment Under The Hood The Adjustment Is At The Shifter You Have To Take The Boot Out And Look At The Cables They Are Going To Have To 10mm Nuts Thats Where You Adjust But I Really Dont Thung Is The Adjustment If The Car Was Find Before>>>>>>also You Mentsion That It Pops Out Of Gear If It Pops The Problem Is Inside The Trans Could Be The Gear That Is Worn Or The Hub And Slider
Offline
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
Car running weird after shifter upgrade mnetwork Newbie Forum 2 05-12-2006 10:06 PM
90 trans in a 91 car? Its awd.will the shifter linkage have to be swapped? warp9 Drivetrain Tech 2 07-25-2005 07:18 PM
Shifter Linkage Empyrials Problem Diagnosis 1 10-27-2004 04:14 PM
adjust shifting linkage........ eclipse0508 420A Bolt-on Tech 0 07-29-2004 07:34 AM
shifter linkage TalonBlitz00 Drivetrain Tech 6 12-12-2003 04:02 AM
Page generated in 0.11058211 seconds (63.65% PHP - 36.35% MySQL) with 10 queries
