Leaking clutch fluid
Freddy
Jan 3, 2003
My clutch fluid leaks. It is a slow leak, but since the resavoir is tiny I have to fill it all the time. I assume is on the slave or master cyllinder, but I haven't had time to really look. It didn't start until I used a nitrous shot. Some times the clutch won't through until I pump it a few times. I am getting ready to buy a Centerforce Dualfriction Clutch (or ACT 2600), but I can't find master and slave cyllinders for sale. Were do you get them? Will the leak reaccure under graeter increases in horepower?
Thank You I am new at this and any help would be greatly apreciated!
Check Conicelli Mitsubishi (spelling?) or Talahasee Mitsu, booth have "DSM Club" discunts on all parts. There is also another place that sells master and slave replacements, I'll have to look for the link. They had both master and slave package for 130 bucks or so.
o.k. my clutch fluid also leaks inside my car. its leaking from the pedal it self. so, is replacing the master and slave cylinder a fix to this kind of leaks too? i dont know much about the drivetrain area....so pls help me too...thanks!
Mine leaks inside the car. Its the Master clutch cylinder that does that. I just picked up a new one at AutoZone, it was $90. It says Nabco on it, and I believe thats what the OEM cylinder is as well.
