JWoodley
- 736
- 4
- Oct 12, 2002
Middle Of Nowhere,
Alabama
Hey guys,
My master cylinder crapped out, so I replaced it. (Its in a really crappy place with very limited space. If you've never had the pleasure of replacing one). Anyways, after the installation I can't seem to get the car to crank. I made sure the battery had a full charge but still a no-go. I believe it is possible that I may have goobered up the clutch switch. Any ideas?
Here's some background info:
Also, after having a shop adjust the clutch it started slipping on my way to work. Just a tad bit around 3500-4000rpms. On the way home I couldn't get the car into gear with the car running, so I cut her off for a few seconds to let everything stop rotating. I started from a dead stop in second. Just as soon as I turned it over I had to give it gas as the clutch was not disengaging. I could make the 2nd-3rd shift with no problem. So I limped her home 25 miles at 35mph.
I've got about $1500 worth of goodies coming in from Modern Performance and I'm wanting to make sure the car is in driveable condition before I toss on the mods. The good thing is I have an ACT2600 with street disk in my room and the Fidanza should be here by the middle of the week. Should I go ahead and drop the tranny to assess the damage or should I get her running first. Thanks in advance guys!
.. theres that safety feature with manual cars that don't allow the engine to be started unless the clutch is pushed in and pushing that button.. just tryin to help
