Spike3099
- Oct 3, 2002
New Milford,
Connecticut
hello, I fixed alot of kinks I had to change the master and slave cylinder, clutch was fine for a day but now it picks up at the top right at the top actually used to be at the buttom I have adjusted that rod clockwise alot of times and it has not moved. any ideas as to what it might be? also I know the 3500 is only 2500 pounds but if i shift hard engine shackes alot you think I should get polyurethane mounts? thanks
. do you think I have to change the slave rod?
