ASZRAEL1266
- 895
- Oct 15, 2002
My center support bearing for my drive shaft came lose while driving. How hard or easy is it to replace this? How long would it usually take to do this? I had my transfer case replaced about 2 weeks ago by the dealer and this bearing came lose Monday. Do any of you know if this problem could be because the tech that fixed the car and put the new transfer case in didnt tighten down something or put everything back on correctly? I called the dealer and they said I would have to have the car towed over there for them to check to see if the problem with the car is their fault. If it is not there fault then I am going to be stuck paying for the dealer to fix it and one fat towing bill. Could any of you give me some advice as to what I should do? If its not a major thing then maybe I should just have the shop that my car is at now fix it. Any feed back on this would be much appreciated. Thanks
