only one 24mm bolt on tranny?
ChrisFlo
412
2
Aug 29, 2004
Tucson, Arizona
I'm about to change the tranny fluid and wanted to make sure that the 24mm bolt for the drain is the only bolt on the tranny that size, so that I do not undo the wrong one. I looked at it and the drain plug/fill plug was different that this picture....
http://www.vfaq.com/mods/wayback/BradBauer/drivetrain/Transax_plug.jpg
The fill plug is in a similar location but the drain plug looks to be facing towards the passenger side of the car instead of in the same direction as the fill plug. Thanks for any help you guys can give.
you are correct, that is the drain plug, i dont believe that there is anything else on the transmission that is 24mm, so dont worry about messing anything up, the 17mm is the fill. Gl man,
-Seth
hey guys sorry to jack you're thread but i changed my fluid yesterday and neither of those plugs are on my tranny,and i mean this seriously my fill plug looks like the drain plug in that picture and it's directly on top of my tranny rite under the shift linkage,and my drain plug that looks like the fill plug in that picture is nowhere near the drain plug in that picture move it over 4 inchs and thats were mine is<now i just bought this car and i'm in canada does this make a difference or wot??? also it's just a 5 spd tranny,FWD any help would be greatly appreciated,this kinda has me worried as to wot the hell is in my car
