river
- 282
- Jun 9, 2004
Anchorage,
Alaska
I own a 1990 Talon TSi and during every shift while the car is moving the transmission grinds. however, if the car is stopped the gears can be shifted with the clutch pressed in and you will hear no grinding. so if i am at a stoplight and i put it into first there will be no grinding, but after the car is moving you will hear a grind from each gear. the only way to avoid the grind is to shift very lightly and not pull the car into gear, rather just ease it into each gear. i am wondering if the synchro is going out, or what the problem may be. keep in mind that the clutch is fully depressed at the time of each shift also. anybody have any ideas?
