lancer evo3 dragr problem
evo3marcel
Jul 5, 2006
borculo, Europe
Hello my name is marcel van dale from Holland Europe:
I have the following quistion last year my lancer evo 3 made a 10.8 run followed by a 10.7 run top speed of 203 km/h
the set up was this, full prepped block with a hahn 20 g turbo running on sunoco 120 plus ocktane . drag spool front diff lsd rear diff lsd . kg/mm suspention and Hoosier dragradials . all other rubbers are ralliart items
This winter we made a small rebuild to the engine, packed the engine in powerflex polyuhrthane engine mounts , magnus intake 63 mm trottlebody removed the front 1 way cusco lsd making me grazy. the suspention was changed to an AST/ARAGOSTA full ajustable coilover kit instaled the ALS function on the autronic pnp computer and now driving on Toyo R888 (more slip)and sponsering of Toyo. the problem is that the my evo is slower on the same strip as last year 11.5 at a top speed of 198 km/h.
What do i did wrong ??
I bought a garrett gt 35 r o.82 in the meanwhile
what was your 60ft? you need to compare your 10.7 timeslip with the new 11.5 timeslip and see if the difference is in the first 60ft or down the stretch. If it is down the stretch look and see what point down the stretch you started getting slower. with all the changes you made in your suspension, you probably need to launch the car a little different or adjust your suspension different.
first ist was a 1.47 and no it, s2.0 plus i was thinking that the hahn td 06 could not bring enough pressure but now i think it,s is in the suspention department. this is our website www.coltco.nl thanks
your problem is definately in your take off(60 ft.).Would'nt hurt to check for boost leaks. What clutch are you using and how old is it. possibly a slipping clutch too. what do you have your coilover settings at?
