Engelstine
- May 30, 2002
hey guys..i just have a quick inquiry..over the spring/summer i wanted to do a stroker rebuild project in my garage..i was wondering what all is involved in this..i know i gottaget the pistons,rods and that..but machining wise.what would have to be done..if someone has a page that has steps on how to do that rebuild that would be cool..just thought it would bea fun project to do..thanks guys
Enter Devil's advocate mode: Since you need to push the pin up higher with any stroker application, you begin to interfere with the oil control rings which can cause premature wear, although oiling may be slightly improved. Once you push the pin up, it usually means pushing up all three rings including the upper ring land which you really don't want too close to the heat of combustion anyway. Remedy? Taller block deck. Wouldn't that be nice.
