96gsdsm
- 194
- 7
- Sep 10, 2005
Milwaukee,
Wisconsin
This problem has been plagueing me for over a month now and I'm
but here goes...
I bought my tsi (profile is up to date) about 3 months ago. It was rebuilt with all OEM parts from the top down 6k miles ago by the previous owner. I have reciepts and everything. Well... the s16g that the car came with looked like it sucked in some debris, because I could see dents in the fins. I figured I would just drive it untill it went and get myself a nice new Evo3. So one day I let the car warm up, leave the house, hit boost ... and literally 1/2 ways down my block I glance behind me and see the dreaded white plume (synthetic white) of a blown turbo. Before this there was absolutely no smoking at all. period. Ok, no biggie... I bought that evo3 I always wanted... Installed it... started it up... more white smoke. I figured it was burning off so I let it idle for about 1/2 hour untill It got darker and I could open it up down the block. Same thing... smoke EVERYWHERE. So (to shorten this story up some) that evo3 had a 3/4" sliver of metal jammed in one of the turbo bearings, I shipped it back to Forced performance, and they rebuilt it under warrenty and I recieved the rebuilt one today.
I installed the turbo again.... same thing. It's still eating my oil up. So I actually removed the turbo, took it apart, and checked the bearings for more crud. ... nothing... absolutely perfectly clean. So I reinstall it and it still smokes. All the time. Idle, under boost, cruising ... everything.
Keep in mind the car ran PERFECT before all of this.
I removed the elbow that connects to the compressor housing and I can see a small pool of oil at the bottom inside the compressor housing. ... So I hooked the MAF up directly to the throttlebody elbow... bypassing the turbo's intake system... and it STILL smoked. I can see oil being forced through the crack in my crappy 1g exhaust manifold ... and it also drips slowly out if the 1/8" wide hole in my flexpipe. (1 drip every 3 seconds at idle)
There is no oil in the antifreeze or vice versa.
Compression is (#1-2-3-4)
dry 140- 90 - 90 -100
wet 175-100-110-150
I'm at my wits end. Any suggestions/tips/hints would be great.
but here goes...I bought my tsi (profile is up to date) about 3 months ago. It was rebuilt with all OEM parts from the top down 6k miles ago by the previous owner. I have reciepts and everything. Well... the s16g that the car came with looked like it sucked in some debris, because I could see dents in the fins. I figured I would just drive it untill it went and get myself a nice new Evo3. So one day I let the car warm up, leave the house, hit boost ... and literally 1/2 ways down my block I glance behind me and see the dreaded white plume (synthetic white) of a blown turbo. Before this there was absolutely no smoking at all. period. Ok, no biggie... I bought that evo3 I always wanted... Installed it... started it up... more white smoke. I figured it was burning off so I let it idle for about 1/2 hour untill It got darker and I could open it up down the block. Same thing... smoke EVERYWHERE. So (to shorten this story up some) that evo3 had a 3/4" sliver of metal jammed in one of the turbo bearings, I shipped it back to Forced performance, and they rebuilt it under warrenty and I recieved the rebuilt one today.
wet 175-100-110-150
