FS:Built trans+drivetrain/injectors + performance
taylorvw
35
Dec 13, 2008
regina, SK, Canada
tvanwoert's Library | Photobucket
Hello and good evening. A project that has slowly lost importance to me is taking up useful space in life. So as many of you may have possibly experienced, the need to keep excessive amounts of aftermarket parts in hope that one day the future will allow use of is rather unrealistic. The sad reality has sunk in and money is now taking priority. All parts are located in Regina Saskatchewan and I have no problem shipping at the added cost for the buyer. I have pictures of everything and can take many more, still working on figuring out a way to post them. For now I can email or for fastest response text photos. (306)591-6261.
Buscher racing "Buschwacker Stage 1" transmission. This is a 1990 style trans, meaning it has a 21 spline output. On paper it has had a the following NEW parts installed, 1st/2nd/3rd/4th gears along with a new intermediate shaft and the option of a welded center diff was added aswell. This transmission was installed / removed and has less than 10km on it making it next to brand new. Asking $1500, more than willing to workout a deal with other parts in this add.
ACT 2600 clutch kit. Clutch disk+ pressure plate, these items both have under 150km on them. About 75km on them were on an UN-adjusted clutch which is why I assume there was a small burn mark upon removing. Once again these are both damn near new and if you can deal with the cosmetic scratches n nicks why not save a couple dollars. Asking $325, will include the bnib act throw out bearing aswell new PP mounting hardware from ziggy.
ACT Streetlite 6 bolt Flywheel. This flywheel aswell has seen less than 150km of street use, next to new and designed for a 6 bolt crank. Asking $200, for $20 more I can throw in OEM extended flywheel bolts.
Dynapak Clutch kit for 4g63. Includes pressure plate, clutch disk and a NSK throw out bearing. This item was never used, part # NU0107. Asking $150.
I have two 21 spline transfer cases purchased off a fellow member during the summer months. One of the tcases (cleaner one) has new seals installed. The other was a spare. I will ask as the previous seller did, $80 for the tcase with new seals , $50 for the other. $100 for them both.
BNIB 900cc Fuel Injector Clinic injectors, had intentionally purchased these to use with an FP green and never got to that stage of the build. Will include pigtails with purchase, all injectors have brand new o-rings from top to bottom. Asking $380
4x Evo IV 510cc yellow top injectors, swapped these out for 560's at 111xxx km. They may be a good upgrade or just a tool to diagnose and or replace a dirty one. Asking $80
AEM Uego, have had this wide band for a couple years and for over half that it's been on a shelf. I bought a new sensor just incase but the one that came in was for a inovate. Not entirely sure if it needs a new sensor or not, you may get away with a cheap gauge. Asking$100
Innovate MTX-L wideband o2, this item has been used for less than 150km, great wideband and still in its origional plastic. Great condition and still contemplating tossing it in the Evo. Asking $200
Evo 8 Maf, purchased off a fellow member in the summer months. I never got around to actually use this sensor or the adapter purchased with it. Asking. $80 or $100 with 1g harness adapter.
Evo 1 Maf, have this from a previous Evo worked and is currently a spare. Asking $65
2 x 4g63 head gaskets, Rock gasket $45 and the other is a ITM $45 aswell. Also have what I believe is a 6 bolt front case gasket, valve seats and some misc seals.
Lastly a fujitsubu 3.5" Axel back from a cat back system off a Evo 1. Asking $200
Text for fastest response (306)591-6261
All parts located in Regina Sk.
    • sanmantsi72
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
  • Wanted 4G63 800cc injectors
    • DSM_Thorpe
