Manual Boost Controller
What kind of MBC do you have, turn the screw the other way, I did the same thing with mine. . whoops, spring was to hard, changed springs, now I get 15psi every time, cost me about 6 bucks at lowes:)
BoostedTalon
Umm... with most good MBC's, if the screw is all the way in you'll have max boost. You probably want the screw OUT.
Originally posted by OneFastEclipse
Alright. You guys are probably right. I had the screw turned in as far as it would possibly go. So I need to turn it counterclockwise (out) in order to lower the boost? Just freaked me out when I got out on the road slammed the gas and it hit 22 psi on stock fuel. This is the link to the BCS that I have. http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=42604&item=2457226617
Thanks alot for the help!
Yes, unscrew it for that one. Only with a bleeder would you screw it in.
