injector installation prob.
kdrkmstp
124
Nov 4, 2002
I tried to install my RC 550 injectors in over the weekend,
and when i turn the key to on position it made clicking noises,
and when i turned the car on gas was leaking.
What my question is, is the top lower insulator suppose to go
into the fuel rail or right below the fuel rail??? Mine stayed below
the fuel rail. Also if I buy new o rings and etc from Road race engineering, is it the same as stock ones???
Sounds like he didn't put the green o-rings from his stock injectors on the new ones. It sounds like he just jammed the new injectors into the rail with no o-rings. When the fuel pressure came up it poured fuel on the ground.
I had the same thing happen to me.....but a new seal kit took care of that.
Should I just go get some new o rings and insulator from Mitsubishi,
or get one from RRE. Is there any difference???
The stock o rings that I put aren't green, they were like pale yellow...
