Spdrcr7882
- 105
- Jan 6, 2003
Danbury,
Connecticut
I am beginning to get fed up with all the problems that come with dsm's. I am kinda startin to think i mgiht want an easy way out. not to sell the car but an easier turbo setup to tune. I bought the rs 65 from agp about 5 months ago
RS65
-65 lb/min compressor
-56 trim GT40 compressor wheel
-76 trim T350 turbine wheel
-T04E (3" inlet, 2" outlet) or T04S compressor housings
A friend at work offered to trade my his big 16g and some money for my turbo. I will need to spend another 300 to have an external gate put on my car, since i got this turbo with an internal gate. I wanna keep the 56 trim and get it tuned, but i am not sure how much power i can make with my mods. Will a big 16 with a set of HKS cams make anywhere near the saem power as a 56 trim without cams, both on pump. My internals on my engine are stock and i would not want to put 1500+more into my engine to build it up. Which turbo will make me more power on stock internals wiht pump gas.
Thanx
Justin
RS65
Thanx
Justin
, when you bend rods and not just having little compression leaks then you know you are making some power
