Violater101
- 1,051
- Apr 16, 2002
Okay, I have a FP Green with 40mm Tial and a Profec B with an .8 bar spring.
Problem ...boost goes to 15lbs, then keeps creeping up to 20 where I always let off the gas because I don't have the injectors unless on race gas for that much boost currently. Kinda stumped. I hooked up the Profec like the manual says and I've adjusted the 4 switches on the back of the profec unit and still no luck. I'm using the poppet valve instructions.
I think it could be due to wastegate opening on the turbine housing being to small because I get the same results if the profec is off. Oh, forgot, I got the gain all the way down and the boost all the way to the left which is minimum boost possible ..should be like 11 or 12 lbs max.
Basically, i got the hose off the profec unit going to the fpr hose. Then I have from the wg, from the top going to bov return line (which feeds to the intake manifold). Then the side hose off the wg is going to I believe the "Out" on the Greddy motor unit. Then the "In" on the Greddy motor is going to the turbo. Not that it should matter, but this is on a 2G. I can't remember for sure, but I'm fairly positive that's how its hooked up currently. I have tried a coupel different ways with the same results.
Could anyone with a Tial External on a 2g with profec b tell me how they have there's wired?
Thanks for you help,
Chris
Chris
