jfdid
- 267
- 1
- Dec 18, 2003
Calgary,
I was driving in my car and revved it hard....7000 rpm, and all of a sudden I lost all boost. My turbo is making a loud vacuum cleaner type noise. There is oil leaking down from the turbo, it's all over the compressor housing and the wastegate actuator. The car runs fine, but there's no boost. Did the shaft/bearings on the turbo break? Thanks guys
Easy Fix. Just look around ur intake components. You could have a IC pipe that popped off. Good Luck
