crash27578
- 277
- May 5, 2003
Livingston,
Tennessee
I'm going to port my turbo when or if my new eliminating downpipe from RNR ever comes in!!! I was wondering about what grit sanding tool should I finish with?
I use a rounded bit with straight sides most of the time. A smaller diameter ball tip is useful along with something with a point to get into tight places. I usually find mine at swap meets and car shows. The vendors with all the tools sell them for $5 to $10 each and have a huge assortment.what type of bits do you use? i realize carbide is the type but what size, shape ect
It's not really worth the time. If you smooth everything out with the carbide there is a slight roughness but not enough to hurt flow by any measurable amount and it doesn't collect any more carbon than the stock casting. If you were doing the intake on a N/A car it might be a different story. It certainly wouldn't hurt anything to do it, though.There is some point to doing a little bit of polishing.
