need opinions on a 6-bolt build up
ams has a combo..I think egale ods and ross forged pistons...there a bit pricy but worth every pennie from whta I hear.
im doing a build up right now, im going with ross pistons/eagle rods, all arp hardware, mls head gasket, clevit bearings, slow boy stage 3 head with all crower hardware, hks 272's, and for ailttle more get a magnus intake manifold u will be just fine with that LOL.
this is the setup ill have at the end of this summer so we will see
Eagle/Ross combo is a good choice.
Also you should go with ARP main and head studs and make sure your machine shop uses a Torque Plate http://www.engintecs.com/gallery/album07/Torque_hone
and Align Hone the mains
http://www.engintecs.com/gallery/album14/Align_hone2 .
Mitsu MLS gasket will require very straight and smooth surfaces on both Cyl Head and Block
http://www.engintecs.com/gallery/album14/Done
All these will support more than you can throw at it if tuned right .
Don't forget an upgraded Head that produce that kind of power.
