major or minor problem?
1BADBIRD
57
Dec 19, 2002
JACKSON, Mississippi
Wheen i crank my car, i can smell oil burning.. If i let it sit for a couple of minutes, a little light blue smoke comes from the exhaust.. I then get in it and tap the gas and a big puff if light blue smoke.If i am driving the car it wont smoke, but if i let it sit for a few minutes, same results.. I have changed my oil religiously at every 3000 miles or sometimes when the oil is black(before 3000miles). I took it to a local mechanic, he says it could be two things,1. damaged valve guides or 2. or the valve stem seals.. What do u guys think.. And what should i do??
Could be your vavles or your turbo might be going bad, or your ring's could be going as well.
Most likely not your rings but it could be a couple of things and the only way to find out is to repair the best probable cause, and see if that was the problem.
:dsm: the turbo has 10000 miles on it barely.. I doubt the rings are the problem, because it doesnt smoke while i am driving it..
could be a head gasket, or rings are bad, some how there is oil getting into the cylinders, could also be coolant, because i think blue smoke is coolant, white some is oil. But there is deffinetly oil or coolant in the cylinders. I had the same problem about a year ago, costly fix. See if u can smell somthing back by the exhaust outlet. Let me know what it smells like. A sweet smell is usually coolant.
one more thing, there are seals on the valves and if those leak they leak oil into the cylinders.
