The Eliminator Turbo?
truwarrior
1,422
6
Dec 19, 2002
Anyone know about the "The Eliminator" turbo from turbochargers.com? Is it kinda like a t28? Anyone useing one?
They put any compressor wheel in a TD05H housing up to a 20G as far as I know. It was an easy install because it's just like the T-25 as far as bolt on ability. As far as performance, it's like everything else...you need the supporting mods if you get something huge.
Hmm, if I go that route I'd probably get the sb with the 20G. Rather get the fp t28 before I get a modified 16G though. Would I need a install kit if I get the sb raceing modified turbo?
There are two eliminators.. One is the 16G with the new cover and the other is a 20G with the new cover... As far as an install kit goes, it still uses a Mitsubishi core so you need a new return line for the oil as well as having to bend your water lines.
