Spln_Hrd
- 1,707
- 8
- Oct 20, 2003
Hastings,
Nebraska
I have Ported out the wastgate entrance. I have ported to help the flapper open more. I have an external dump 02 housing. I am now considering porting out the exit hole where the flapper shuts, is there any room to increase the diameter without intalling a 34mm flapper. I dont want the 34mm flapper because of losing the potential of the turbo. Then again maybe the flapper will still blow open if I increase the diameter anyway. I dont know what to do. Id rather not spend big bucks on an external wastegate. I want to eliminate it through porting. Id even send it to a shop that is damn good at porting.
Has anyone eliminated creep on a 16g without installing a 34mm flapper running 3" turbo-back exhaust with a testpipe?
It will increase drag there for the air that does have to go through the turbine.
