help with MSD 2 ignition
powerdbydsm
62
Sep 20, 2003
Portland,
I am looking at buying a MSD ignition from a guy online.
here is what he has said about the ignition.
your looking at the MSD Digital DIS-2. this ignition system is great. it is fully customizable with multipal swicths on the side to change, MAX Speed Rev Limit, High Speed Retard, Staging REV limit, Retard begin speed and may other settings. Made for 4 cly with 2 coil packs.
The Coil Packs are made for GM vehicls.
The coils packs are alittle dirty but still in great condition. The MSD Works great! there are a few skratchs on the box but other then that it looks great! This kit cums with every that came in the box when i frist got it. all the bolts,wires and coil pack scerws and 2 bypass plugs.
My question is will these coil packs work with my car??? I know the ignition will.
Thanks :D
Good luck making them work. If you want to make them work you will also need the adapter plate. Then you have to figure out how to make a 3wire dual coil wire upto a two 4wire individual coils.
I coulnd't figure it out so I got rid of them. Never mind that you'll have a hard time finding a spot for those coils under the hood of your car too.
