pickens
- 544
- 5
- Jan 17, 2003
Southern California,
California
Here's the deal. I think its time for an afc and 550cc injectors because if I run anything over 15 psi, I get a studder between 4-5k rpm, but then it pulls fine to redline. On the log, it looks like timing is pulled for a second at 4.5k rpm, and then goes right back up until redline. Is this fuel cut? I searched and I read fuel cut was either a complete shut down of the motor, or it could also be a studder. If it is fuel cut, will an afc and 550cc be good enough to get me to about 20psi?
I'm on a 14b. But yea youre right, if I was on a t-25 there is no way you can get fuel cut. Its next to impossible.
