Fuel cut defencer mod
JC-GSX
Jul 31, 2002
I was looking at the mod in the vfaqs to wire a potentiometer into the ecu wiring to prevent fuel cut. After you wire in the potentiometer are there any adjustments to make since the potentiometer rotates or do you just hook up the wires and go?
hmm, not sure how to answer your question but be careful man, fuel cut is your friend.. its there for a reason..running to much boost can hurt your engine if you dont have the right supporting mods first
actually sometimes fuel cut isnt your friend. I can hit fuel cut at 12psi if I wanted to. Just crank up the fuel on the AFC. Although I dont know why anyone would want to do that... but still, if you have a datalogger fuel cut is a PITA rather then a safety thing.
