thedsmsource
- 63
- May 2, 2003
Hell Everyone, This is my first post on the board after 9 months of listening in and doing some research. I have been gathering the parts and materials to assemble my motor, and i am finally there. This wil lbe my first dsm engine i will ever assemble, so i am looking for some simple tricks, tips and things to look out for that maybe one of you have done in the past by accident and would like to share so hopefuly i will not do the same, here is the engine that i am assembling.
-Block-
2.4L Block 6-bolt with 1G style mounts
Pauter Machine Rods
Wiseco pistons 8:5:1 machined to end up with a 8:1:1 ratio
Arp Head and Main studs (using pauter rod bolts)
Fidanaza Aluminum flywheel
Act 2600lb clutch set with stock throwout bearing
New water + oil pump
All new Fastners
Sealed Power Bearings
No balancing shafts
-Head- not allot here
Port and Polished including bowls, gasket matched intake,
New bronze valve guides all around
Ultra-Sonic Cleaned because i am anal over clean stuff
1mm oversized valves, black nitrate coated
HKS Valve springs
Crowler Retainers (titanium)
-Head + Block machine work-
Rotaing mass all balanced
Bored + Honed on torque plate
Crank all checked, nitrate coating???
All surfaces re done, etc. etc.
-Tranny-
Rebuilt myself
JDM Galant EVO gears (look in vfaq table)
New bearings, shimed etc. etc.
Not sure on center diff yet, need Suggestions
- Turbo- Only thing not purchased
AGP T3/T4 setup
Most liekyl 60 trim, not 60-1, but need suggestions
Top Mount Intercooler
Right now i just have to come up with a thickness for the head gasket to maintaine my compression ratio. Custom camshaft will be made as well after the cc-ing is done. Right now i just need to decided what to you with the center dif, spool, or maybe 4 spider gears? And the turbo of course. Any suggestion would be great. Any idea of what i should be looking at hp and 1/4 wise? Thanks guys
-Shain
-Block-
Pauter Machine Rods
All new Fastners
No balancing shafts
HKS Valve springs
-Tranny-
Rebuilt myself
AGP T3/T4 setup
-Shain
