New uppper intercooler pipe.
90AWDTalon
877
3
Jan 5, 2003
Everett, Washington
I installed this 2.5" upper intercooler pipe I bought off ebay, cost $125. The guy also has a web site he sells them from but they cost more there than they do off ebay. http://www.straightlinespecialties.com
When I recieved it I was really impressed with the build quality. I realized it wasn't going to fit with my cruise, so I ordered a non cruise throttle cable. I never used cruise anyways so this was no big deal. When I installed it I was a little dispointed in the fitment, but I got it to work. First, when I went to reinstall the BOV on the new pipe I realized the flange wasn't threaded like the stock flange. I went in the house and found a couple of bolts and nuts to use, but it would have been nice if the hardware came with the pipe or there was a warning that I needed to buy some. Second the flange on the throttle body elbow is smaller than the stock flange. At first this really worried me, but since I had already removed all the stock stuff and was so close to being done with the install. I decided to see if the mounting bracket attached to the throttle body elbow and cas would suck up and not cause a leak. I did get it installed, so I next went for a test drive.
Before this install I had the boost set to 17psi, I left it there for the test drive. First thing I noticed was the throttle response was incredible, it felt like a whole new car. Next I noticed the boost response was greatly increased, in lower gears I was hitting full boost by 2600 rpm's, previous to this pipe it was about 2900 rpm's, and in higher gears I was at full boost by 2500 rpm's. This should really help me with autocross, the slow boost response was my major complaint while auto Xing. Next was a full pull through 1st, 2nd, and 3rd. It was pulling a little harder, not quite what I was expecting but I was still really happy with the improvements in throttle response and boost response. When I got home and looked at my log I realized why it was only alittle stronger. I was getting about 20 counts of knock and the timing was being pulled. I was now pretty impressed with how it excellerated with the timing being pulled as much as it was. I new I needed to turn the boost down to get the knock under control. I reset the boost to 15psi, pulled hard as hell and almost no knock, just alittle bit of tip in knock from being a little rich. Next I'm going to turn the boost up to 16psi see if its a good middle ground.
Over all I'm really pleased with this pipe, a thicker flange on the t-body elbow and some mounting hardware for the BOV would be nice, but I'm happy with it.
Here's some pics
<BR><BR>
<BR><BR>
<BR><BR>
Originally posted by AW4G63
UICP is the best basic mod .
Actually, stock 1G upper I/C piping is not as bad as you might think. I am sure that upgrading it must help “some”, but I have seen numerous mid 12 sec cars upgrade their pipes and not see any measurable results in the ¼ mile. Based on that observation, I have always told people that you will not see any performance gains until you are in low 12’s (but even that was more of a guess).
This is a fine mod, just make sure that you know that you are doing it mostly for looks…
And whatever pipe you use, it MUST have be well designed (good beads, couplings and clamps). There is nothing more frustrating than blown off pipes.
Leon
RR
Originally posted by RuBiCaNT5X
Why don't you have that GM MAF setup to blow through instead of draw through? There are so many advantages going with the blow through..
There's not any real performance benefits to blow threw vs. draw threw. Most people are doing it so they can vent, and make their BOV louder. With my current set up the BOV is already very loud, I can hear it over my exhaust. I'm more about function than looks or sounds, so I'm sticking with draw threw.
