whatturbo
- 73
- Jun 6, 2002
St Augustine,
Florida
For anyone that has one of these gauges, did you tap your intake manifold, have a bung welded onto your i/c piping, or use the vacuum line that comes out of the intake manifold to "feed" the boost sensor? I don't want to remove my intake manifold to install a gauge and don't mind having a bung welded to my throttle body elbow if I need to, but it would obviously be the easiest to disconnect my autometer boost gauge and plug into the vacuum line it's using. What would make the vacuum line accurate enough for the autometer but not the SPA digital, or is it accurate enough? Any help from SPA users would be appreciated.
